HI Everyone, I have a set of ER34 GTT Jap spec Bilstein shocks for sale, selling it due to the upgraded to the coilovers. The shocks have fitted with a set of Kings springs at 48000k and the shocks were took out from the car at 53000k. So the shocks done around 53000k for its life and the springs were done around 5000k. All the work were done by Centrax the Endless Official Distributor in Australia, and they also did the inspection after the shocks were out. There is no leak and in 100% working condition for all four of shocks. I am selling these for $380, price are neg, interstate buyer are welcome but please organize the courier because they are heavy and I work from morning till late. Inspection can be arrange if you are living in Brisbane.
Also have a brand new front tow hook. This hook is new never been use, was plan to use it in my car but it is too short to fit, it was sitting behind my front bar. Selling it for $40 and will post with buyer expanse
Any interest please send me an SMS to 0414963354 or send me a PM thank you!!
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
