A while ago, I saw an orbital polisher on special for $30 at Autobarn, so I thought meh, might get it and see how good it is.
After being in the box for a few months, I put it to use tonight.
I pulled my front bar off today for a touch up, so I thought I might as well take out my headlights for a clean.
Sanded it with 1200 & 2000 grit then finished off with a hand polish. After hand polishing it, it was still a tad murky. So I gave the polisher a go, and after a few mins.. The headlights look brand spanking new again! :D
But I have a question, what do I do with the buffer pad? Do I just wash it and dry it?
Here's some pics:
(Top headlight is hand polished and bottom is machine polished)
https://www.sau.com.au/forums/topic/370677-30-orbital-polisher/
when i worked in mitsubishi in pait rectification they were just put through a washing machine, at home i just wash in the laundry tub with water.
Cheers, will clean it tonight :)
Also, any tips on polishing my car with that thing? lol
First we used a rotary buff to polish with, then the orbital with an egg crate type pad to get rid of marring (the swirly bit you see after polishing) sort of like what you see here http://www.ebay.com.au/itm/6x6-High-Gross-PolishingPad-Buffer-Pad-Car-Polisher-/180681082040?pt=AU_Power_Tools&hash=item2a116e84b8 but its for velcro backed polishers. Just make sure the polish doesnt get too dry and keep the pad clean.
First we used a rotary buff to polish with, then the orbital with an egg crate type pad to get rid of marring (the swirly bit you see after polishing) sort of like what you see here http://www.ebay.com....=item2a116e84b8 but its for velcro backed polishers. Just make sure the polish doesnt get too dry and keep the pad clean.
I bought black waffle pads from that seller; they're great! Bit slow on delivery tho'
This is what I did with them yesterday:
Reflection? post-61153-0-26778900-1310425114_thumb.jpg Try not to look at the ugly bloke; post-61153-0-56895300-1310425163_thumb.jpg
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
