Hey i have to sell my r33, im heading to Port Hedland on Tuesday for work and will not be back for a while
its a 1993 model s1, 5 speed with 136000km, white
I just replaced the radius rod to chassis bushes and all other bushes fine
it has a 3" exhaust from turbo back, apexi pod filter, hks turbo timer, gfb atomic boost control set at 10 psi and has only been fitted for not even a month and i also changed the spark plugs at the same time
sparco wheels, also with another pair of 17" wheels, comes with standard air box and boost control lines, brass button clutch, greddy oil catch can
well looked after, i have only put 6000kms on it since i have owned it and has not missed a beat, done a few trips to sydney and has been great, i dont want to sell it but it is silly paying for rego and insurance if not driven
S2 seats
body is striaght apart from two little dints in passenger door and front bar has a crack in it, serviced and it has had a 100000km service as well with gates timing belt
runs out of rego on the 19th of this month but i can put rego on it for u if u like, $6000 no rego, $6900 with rego
Great car, only selling due to moving away for work, would love to keep it
0414269271 give me a call if you have any questions, located in Newcastle
Edited by hypo33
https://www.sau.com.au/forums/topic/371004-r33-gts-t-s1-136000kms/
will swap for a ktm250exc or ktm300exc 06 model and up
I have a Ktm 250 SFX. if u are interested ?
Its in good working condition needs a new cover for the air filter. can take photos and p.m if u like ?
Sorry mate im really after a road rego 2smoke
  • 4 weeks later...
  • 1 month later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
