Item: GReddy PRofec B II
Condition: New
Comments: Controller is black.
Price: $400
Item: Nismo Timing Belt
Condition: New
Comments: Suits all twin cam RB engines. RB20/25/26.
Price: $180
Item: Nismo Engine Mounts
Condition: New
Comments: Sold as pair, suits R32 with RB20DE/T and RB25DE.
Price: $250
Item: Nismo Gearbox Mount
Condition: New
Comments: Manual gearbox mount, suits R32 with RB20DE/T and RB25DE
Price: $150
Item: Nismo Pivot Ball
Condition: New
Comments: I have 2 of these. To suit S13/14/15 and R31 / R32 (GTS-T).
Price: $50 each
Item: 350mm Dished Steering Wheel
Condition: Used
Comments: No boss kit.
Price: $80
Item: R32 Coupe Back Seats
Condition: Used
Comments: No rips, just need a good clean.
Price: $60
Item: R32 Coupe Rear Middle Floor Mat
Condition: Used
Comments:
Price: $10
Contact: Jesse 0420 974 417 or PM
Postage: I'm more than happy to post the small items at buyers cost
*Please note with all the new items they are brand new, never used and the boxes only opened to inspect the items.*
https://www.sau.com.au/forums/topic/371146-vic-nismo-greddy-new-r32-parts/
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
