I thought I would share one of my old projects. In the search for my braking power, I decided to bolt up some 300mm discs to my Telstar. (yeah yeah, get over it :nyaanyaa: )
I tried fiddling with R32/R33 GTS-t stuff, but I didn't want to cut mounting tabs off the calipers or cut into the knuckles. After searching the DBA catalogue, Integra Type S discs seemed like a good choice as they were close to being identical except for the increase in diameter as seen below.
I decided to make up a dogbone bracket to mount the standard caliper bracket, so made a template out of 19mm thick wood to make sure my measurements were right. After I had it all sorted, I then machined it up at work and turned up some stainless steel sleeves. Then the brackets were treated to a light bead blasting.
Template/trial bracket.
All done!
Disc size comparison.
Bolting them up.
Sitting behind 16" and 17" wheels.
They've been on about 3 different cars I've owned over the past 4/5 years and have worked flawlessly.
They now have a pair of RS Liberty twin piston sliders in the standard brackets. with Goodridge braded lines.
They are soon to be replaced with EVO 6 discs and calipers front and rear :thumbsup:
https://www.sau.com.au/forums/topic/371698-dogbones-for-300mm-discs/
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
