Hi, I have some parts for C34 Stagea which I no longer require.
Located in Boronia, Melbourne but I'm happy to freight at your expense.
0419-010-757
Cheers, Chris.
1. 3" Cat Back Exhaust - $550
This exhaust was made by Rowville Exhausts in mild steel with a straight through stainless steel Magnaflow rear muffler. It tucks up closely to the body and is relatively quiet. It will pass EPA (<90dB)
2. 16 x 7 Series 2 Nissan Stagea Wheels & Tyres - $450
These have just been painted in gloss black by Bayswater Panels. Tyres are 205 65 16 and are in road worthy condition.
3. Set of 4 5-Stud 25mm Bolt on Spacers - $150
4. Complete Set Front & Rear HPX Brake Pads - $100
These are for the earlier Series 1 Stagea with the slightly smaller brakes as these pads did not fit my 99 model Series 2.
5. Intercooler Piping suit RB25DET R33 GTS-T, R34 GTT & C34 Stagea (Return Flow) - $100
6. Front & Rear Spings - $50
7. Front & Rear Sway Bars - $50
8. Front Indicators - $20
9. Dash Mat - $20
25mm bolt on spacers SOLD.
keen for the rear springs, are ya willing to seperate??
PM sent
hey rob i've replied to your PM
Postage for the dashmat to 2619?
i'm doing the dash mat for $30 delivered but you're now the 3rd person in line to have enquired..
just a heads up the dash mat is not a rolls royce of dash mats, it looks like a SAU group buy custom made kinda thing but some strips of velco and you'd be right.
3. BOLT ON SPACERS >> SOLD
4. PADS >> SOLD
5. INTERCOOLER PIPNIG >> SOLD
8. FRONT INDICATORS >> SOLD
9. DASH MAT >> SOLD
G'day,
I've got 2 questions
1 Have you still got the wheels?
2 Being stock, will they go straight onto a RS V?
I'm only asking because after reading some posts about wheel offsets depending on the model, I'm getting confused about what would fit on my car, being a rwd auto.
Cheers
  • 3 weeks later...
G'day,
Cheers
hey mate sorry for late reply i've been overseas..
yes i have the wheels, yes they will fit your rs-v.
cheers, chris.
Hey there, you don't happen to have that plastic hook thing attached to a bit of string in the boot where u lift up the spare tire panel? =P
nah i'm not wrecking a stagea i just have few bits and pieces - only whats listed.. sorry mate
Yeah still interested in the wheels. I've sent you a pm.
Cheers
hey mate yeh sent u pm, thanks.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
