Hi, I have some parts for C34 Stagea which I no longer require.
Located in Boronia, Melbourne but I'm happy to freight at your expense.
0419-010-757
Cheers, Chris.
1. 3" Cat Back Exhaust - $550
This exhaust was made by Rowville Exhausts in mild steel with a straight through stainless steel Magnaflow rear muffler. It tucks up closely to the body and is relatively quiet. It will pass EPA (<90dB)
2. 16 x 7 Series 2 Nissan Stagea Wheels & Tyres - $450
These have just been painted in gloss black by Bayswater Panels. Tyres are 205 65 16 and are in road worthy condition.
3. Set of 4 5-Stud 25mm Bolt on Spacers - $150
4. Complete Set Front & Rear HPX Brake Pads - $100
These are for the earlier Series 1 Stagea with the slightly smaller brakes as these pads did not fit my 99 model Series 2.
5. Intercooler Piping suit RB25DET R33 GTS-T, R34 GTT & C34 Stagea (Return Flow) - $100
6. Front & Rear Spings - $50
7. Front & Rear Sway Bars - $50
8. Front Indicators - $20
9. Dash Mat - $20
25mm bolt on spacers SOLD.
keen for the rear springs, are ya willing to seperate??
PM sent
hey rob i've replied to your PM
Postage for the dashmat to 2619?
i'm doing the dash mat for $30 delivered but you're now the 3rd person in line to have enquired..
just a heads up the dash mat is not a rolls royce of dash mats, it looks like a SAU group buy custom made kinda thing but some strips of velco and you'd be right.
3. BOLT ON SPACERS >> SOLD
4. PADS >> SOLD
5. INTERCOOLER PIPNIG >> SOLD
8. FRONT INDICATORS >> SOLD
9. DASH MAT >> SOLD
G'day,
I've got 2 questions
1 Have you still got the wheels?
2 Being stock, will they go straight onto a RS V?
I'm only asking because after reading some posts about wheel offsets depending on the model, I'm getting confused about what would fit on my car, being a rwd auto.
Cheers
  • 3 weeks later...
G'day,
Cheers
hey mate sorry for late reply i've been overseas..
yes i have the wheels, yes they will fit your rs-v.
cheers, chris.
Hey there, you don't happen to have that plastic hook thing attached to a bit of string in the boot where u lift up the spare tire panel? =P
nah i'm not wrecking a stagea i just have few bits and pieces - only whats listed.. sorry mate
Yeah still interested in the wheels. I've sent you a pm.
Cheers
hey mate yeh sent u pm, thanks.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
