Ok so I'm pretty sure I know the answer to this
I went and test drove a cheap r34 at a dealership today $15900 was the price but I though what the hey it might need a small amount of work but for the price I'd check it out
The car started up fine no smoke
Was idling at 2000rpm till it warmed up then settled down to 950rpm
Oil pressure and temperature were normal
BUT the check engine light did not turn off it stated on the entire test drive the car also didn't feel very like I expected I've owned and r33 before and the r33 felt like it had way more power
The dealer obviously tried to hide this by saying that when the car was picked up the driver filled the car with 91octane and that was the reason for the check engine light and lack of power
Could this be the case or is it more likely the engine is f**ked?
https://www.sau.com.au/forums/topic/372624-91-octane-in-an-r34-gt-t/
Yeah but had an s13 with a hole in the fuel tank I got it fixed and the stupid mechanic filled it up with 91 octane the car shook and spluttered an no check engine light
This car idled very very steady but just had no power and the check engine light worried me doesn't the light refer to an actually problem with the engine not the fuel supply?
if the knock sensors are registering a high amount of knock then it may come on. easiest thing to do would be to check the fault codes, or have them fill it with premium fuel and reset the ecu and see what that does. generally the CEL refers to an electrical issue (or damaged sensor). won't refer to the physical condition of the engine in 99% of cases
i got some better advice, find another car there is to many of these car on the market to even think of buying one with problems is just crazy remember it's a buyers market.
goodluck with your car hunting.
Yeah I ended up settling for a nice s2 r33 for $9500
It's stock as even has the airbox and SMIC so I'll save the excitement of owning an r34 for another 2-3years
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
