Title: Nissan R33 GTST, ONE OWNER! - PICS UP SOON!
Write up :
For sale is my 1997 Nissan R33 GTST, Series Two, M-Spec. 5 spd -Manual
Imported from Japan, Low kms 99,000ks.
I am the First Australian Owner of this Skyline and im 25 years of age (so no P’plater has had their hands on it or thrashed it before).
Car was imported from Japan through a importer specialist! And was hand selected. (Previous owner was a female in Japan).
Car is turbo yet no heavy or illegal modifications has been done. Car is in A-1 condition from interior to exterior to engine.
Light – Legal mods as listed:
- manual boost controller (currently on 10psi)
- Pod filter
-Tein fully adjustable Coilovers (worth over 2k) (also can supply stock springs)
- Dished 18” 6 spoke drift rims. Tires are 95% + tread -no offset.
- Boost gauges vacuum gauges on pillar. (with a stealth switch to turn off separately if needed.)
- 3” from cat back high flow (branded) Exhaust system. ( also can supply full stock exhaust system)
- Custom Interior valued over $2000.00 including Monza Drift bucket seats. (can supply stock seats )
- Carbon Fibre door pillars.
-Recent cut polish detail. $200 its self.
-new platlium spark plugs, New Rocker cover gasket.
-FULL YEAR REGO !!!
-NEVER been defected by police or even picked on. (no police history, GOOD THING)
-NOTE- Car Is White, With Black Rims, Very tidey.
Car sits GARAGED! As i have company car i don’t use my skyline and the space to accommodate 2 cars at my chapel st apartment is nonexistent! Need car gone!
PLEASE CALL OR SMS ME !! i can SMS pictures and ANY INFO about the car. ALL INSPECTIONS WELCOME including RACV. Nothing to hide! Car owes me over $20,000.
$15,000 ONO make me an offer!
Dezz # 0403-453-061
Located: Windsor / Chapel st, But can arrange meeting point if intrest shown.
PICS UP SOON CAN ALSO SMS PICS ON REQUEST.
<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break">
bump for a fine clean car!
Cheers man! its a VERY tidy car!
PRICE DROP!!! $ 12,500 ono Common guys im offended! i love my baby! shes ONE OF A KIND!! # 0403-453-061 dezz
INTREST SHOWN
buyer has inspected on sunday 7/8/11,
car maybe sold but no deposit left!
Still takeing inspections to view the car as no deposit left as of yet.
Cheers guys! Dezz #0403-453-061
STILL FOR SALE $12,500 ono throw me an offer! =)
:) CALL DEZZ #0403-453-061
Verry clean tidy car! ROADWORTHY READY TO GO :)
Pic taken very recently are attached below- taken on sunday 14th/aug/11
beside my R33 is my mates $100,000 Gtr
Both of us look after our cars to the point we are affraid to park them anywhere!! Come see / drive the car u wont be let down!
cheers peeps
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
