hey everyone, just wanna find out if anyone has fitted say 19x10 all around on a v35 coupe. also any one got some recommendations of some rims that come in say 19x9.5 +20 (or lower) front and 19x10 (+20 or lower) back. or same thing in 20's that will clear the factory brembos. been looking at vossens they seem to but are pretty pricey. i was looking to spend between 2.5k to 3.5k with tires. thanks
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/
  • Replies 43
I saw someone on here or on G35driver with 10" rims all round, not sure if they had Brembo tho. Have you searched the V series Gallery?
http://www.skylinesaustralia.com/forums/topic/233300-v-series-gallery/page__st__600 ..................post 618
http://www.skylinesaustralia.com/forums/topic/233300-v-series-gallery/page__st__480...................post 487
http://www.skylinesaustralia.com/forums/topic/233300-v-series-gallery/page__st__480...................post 498
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5959739
I got Axis Hiros 8.5 front with 245/40/19
and back 9.5 with 285/35/19
I wish when i got wheels i knew a thing or two about them but now i would get these
FIVE AD WHEELS
19 x9.5+35 / 19 x10.5+22.......$1700 shipped
.****Free lugnut kit, valve stems, Hub rings
from Kevin@US-Autotech
As for wheels after all the research i was gonna get Michellen Super Sport tyres for $1300 shipped from tirerack but i ended up getting Hankook K12 Evos (95% as good) and got them for like $1000 shipped (same sizes as Kumo KU31s i have already)
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5959772
check out http://varrstoen.com/blog/
Range of styles, sizes and offsets. They have an sell on Ebay and are set up with a tyre package for like $2700ish.
I'm waiting on my set to arrive, hopefully any day now.
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5960282
thanks guys, what do you think about these rims?
http://www.skylinesaustralia.com/forums/topic/369993-advan-rs-gun-metallic/page__p__5937826__hl__advan__fromsearch__1#entry5937826
would this size fit well or maybe these
http://www.skylinesaustralia.com/forums/topic/373540-lenso-rims-19x10-19-brand-new-rubber/
what are your guys oppinions about these rims and do you think they will fit on my car and look good (v35 coupe in silver)
thanks again
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5960371
I have some very nice Enkei RP03's
http://www.discountwheelsource.com/wheel/wheel-brand-enkei/wheel-model-rp03/wheel-color-hyper-silver/wheel-style-five-spoke
Been having some dramas getting them to fit on my V36, they came form V35. Offsets after further research are very different.
May be for sale unless a little extra negative camber can get them to slip under the wheel arches better on the rears..
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5961015
http://www.discountw...tyle-five-spoke
are you located in wa? also what are the sizes and offsets? i like the rim how much u think you will be after?
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5961152
I have the exact same tyre and rim sizes, with a different tyre brand on my V35 Coupe, with standard ride height, and unknown (to me) offset, but the width simply appears to be "eaten up". They do not look that wide, and people are in disbelief when I point out just how wide the rear tyres are.
I found some uneven ground which pushed one of the rear tyres high up into the guard, and I could fit a finger width between the guard and the side of the tyre. I got the guards half rolled just to be safe under load and cornering.
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5962257
what sort of rims do you like? 3,5 or multispoke? one piece forged or 2/3 piece dished? I'm contemplating getting a different set of wheels, so if the wheels on my car are to your liking, just throw me an offer. size is19 x 9 & 10 +25 f/r Work sc2
Edited by fcruz3r
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5962342
hey mate im interested in a price for these thanks
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5967739
i fitted some AME circular spec r to my v35 coupe yesterday... very dissapointed with the results.
am running 10x9 +15 and 19x10+15... needs lower offset as its quite sunken in the rear. All depends on what look your after tho.
I also have a full set of Racing Hart "cxr" rims in 19x10 +17 all around. these also fit fine front and rear.. however are for sale if any one is interested??
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5970841
I have work sc2 20 x 8.5 & 9.5 +11 & +18. Guards are rolled and car is quite low on coilovers. Never had a prob. Even fully loaded never rubbed anywhere. If u wanna see some nuts fitments tho check these out
www.rimtuck.com/thumbnails.php?vehiclemake=Infiniti&vehiclemodel=G35+coupe&
https://www.sau.com.au/forums/topic/373609-rims-for-a-v35/#findComment-5979847
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
