Hey guys just after a cheap stock exhaust from the cat to the tip, as quiet as possible and as cheap as possible, also open to just borrowing one for a week or two in exchange for a slab of your preferred beer.
Cheers!
Borci88.
https://www.sau.com.au/forums/topic/373861-wtb-stock-r33-exhaust/
A little cheat to pass with your current exhaust is get a silencer tip in the cannon, get one spot weld done to hold it on and then undo your cat, get a thin sheet of metal and puncture some holes in it. Make it the same size as the flange, put it in after the cat and BAM no power and no noise. When you pass, take it all out. Stock exhaust is still not quiet enough to pass(Ive heard from a few on here).
Well that was my thoughts but it's a full EPA and it says on the sheet "Must not have any temporary noise reduction devices fitted". Seeing as theres only two places I can get this EPA cleared I don't want to risk them spotting it.
Guest
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
