Hi SAU,
Up for sale is my 1998 white Semi-Auto R34 25GT.
Here's a quick summary on the car:
- 1998 R34 25GT
- White
- Semi-Auto
- 56,870 on the ODO
- Brand new BC BR Coilovers (Have receipt to prove it (1.3K)
- Brand new Koya Drift Teks wrapped in Nitto NT05 tyres (Traveled less than 50km, also have receipt to prove it (2.3K))
- Brand new Sony front splits and rear speakers (Also have receipts to prove it $200)
- Regularly Serviced with only Fully Synthetic Oils
- Import Papers + Manual included
- Rego until March 2012
- Very clean
- Factory XENON headlights
- Side mirrors with Indicators and daytime driving lights, will also dim when driving lights are on (Factory ones included).
- Lowered (Suspension is adjustable, so you can slam it to the ground or have it as high as a 4WD)
- 3 keys, 1 with remote, 1 normal key, 1 blank yet to be cut.
- 7" DVD, GPS, iPod capable (Cable goes into center box), TV, SD, USB unit.
- Brake Rotors and brake pads have plenty of meat left, as the car has barley been driven and were changed during compliance.
The car is perfect for any P-Plater and awesome to drive, serviced every 5000KM, only Fully Synthetic used, very clean example, non smoker and accident car.
Reason for sale is I have fell in love with MKIV Supra's once again and I would really like a manual (Couldn't drive one before because of an injury).
CAR IS LOCATED IN BENDIGO, 3555, about 1:50mins from Melbourne (146KM).
For people in Melbourne interested.
You can catch the train at Southern Cross to Bendigo (About 1:50mins), get off at Kangaroo Flat Station and I can meet you there to view the car, so no car/bus/taxi necessary.
Inspections available Friday, Saturday and Sunday.
Breakdown on prices:
Stock (Stock wheels + Stock Coilovers) = 12K
BC BR Coilovers + Stock wheels = 13K
BC BR Coilovers + Drift Teks (How you see it in pictures, Stock wheels and Suspension also included) = 15K
Price IS negotiable
I have my eye on a few Supra's, so a quick sale is a good one :thumbsup:
Also willing to swap for a MKIV Supra, must be manual, <130,000KM.
Edited by Converge
Bump!
Price is negotiable, have my eye on a few cars, so a quick sale is a good one!
Bump!
Bump!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
