postage: happy to box stuff and ship
Condition: Varies by item , check pics
Contact: PM or post here
S14/15 SS Dump & Front pump - $100
http://img853.imageshack.us/i/dumpfront2.jpg/
s 14/15Kazama front castor arms - price $200 (Test fitted only, I think they fit r33 as well but you'd have to check)
http://img199.imageshack.us/i/kazama2.jpg/
LS1 coils - $120 for a set of 4 with loom – 2 sets available
http://img849.imageshack.us/i/ls1coils2.jpg/
17x8+30 & 17x9+17 enkei's 5x114.3
Suit s14/15's r32/33/34 etc
freshly powder coated white and brand new 235/45 A032r semi's on 9's, tyres on the 8's are junk but hold air
$1250
16x7 rays engineering +40 4x114.3 - Ultra light and no rash - White with blue wanky writing
225/50 - 2 good, 2 shit
$450
ARC SUMP to suit SR20 - Used (hardly) but Mint condition - $300
Cusco 1-way mech LSD in s13 housing with input shafts/flanges - 4.08:1
ready to bolt in and go
$750
S14/15 Apexi GT intercooler kit - intercooler core, all pipes, brackets & clamps
used but mint
New = $1500, I'm after $650
Carbon Fibre s14 boot spoiler/lip, brand new - $200
Standard & Complete s13 head comes (in a box) with HKS valve springs, HKS rocker arm stoppers, S2 HKS cams & forged pistons on standard rods with arp bolts
Pics of some of the bits below;
ARC sump
Enkei's
Rays 16x7's with 225/50's
Cusco Diff
Pistons - Unsure of brand.
Edited by fly510
  • 7 months later...
  • 9 months later...
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
