1988 GX81 Toyota Chaser Avante factory
Nearly 130, 000kms
1G-GE 2L 6 Cylinder
Factory 5 Speed Manual
TEMS Elec Suspension - Still Works!
Soundstream TV CD/DVD
Rear Venitian - standard blinga ne
Got this car as a trade for my old car so im looking to get rid of it as i dont need it..
Is really clean car, would be perfect for a 1JZ/2JZ Conversion, Still has plastic on rear door trims
(got quoted 3000-3500 for JZX81 cut or Supra/Soarer)
Has good tyres, Fresh 3 Months Rego etc.. 5KONO OR SWAPS, Let me know :-)
https://www.sau.com.au/forums/topic/374023-sa-88-gx81-toyota-chaser/
  • 2 months later...
  • 5 weeks later...
i can get some more pics if ur serious.
an of course, is my daily atm..
No AC, needs regas. i can organise it to be gassed for new owner if need be
STILL FOR SALE/SWAP
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
