Hey guys im selling my sub and amp's.
Up for sale is a BRAND NEW Sony Xplode 12" subwoofer. 1000W enclosed in a genuine Sony box.
Reason for sale for these items is because i lost my license for 14 months and i didn't get a chance to put the Sub in. so its NEVER been used.
Price - $120
Key Features
RMS power @ 4 Ohm,THD 1% : 45W X 2@ full channel driven
RMS Power @ 2 Ohm: 75W X 2 @ full channel driven
Bridgeable power @ 4 Ohm: 140W x 1
S/N Ratio: 90dB
Variable Input Level Control
Input Sensitivity : 250mV - 9.0V
RCA Line and speaker input, Speaker output
Three way protection: thermal, short circuit and overload
Soft delayed power on
Two mode speaker connection stable
X-over switch: HPF/FULL/LPF
Variable Low pass crossover: 50Hz - 300Hz
Variable high pass crossover: 50Hz - 300Hz
Frequency response; 20Hz - 20KHz
Bass EQ switched: 0dB - 12dB
Fuse: 20A X 2
Only used for maximum of 2hours practically brand new
JB Hi-Fi are selling it for $89
http://www.jbhifionl...ower-amp/436116
Im selling it for $75!!!
Maximum Power Output
500W
Rated Power Output (14.4V )
40W x 4 at 4ohms (20-20kHz 1.0% THD)
60W x 4 at 2ohms (1kHz 1.0% THD)
130W x2 at Bridged 4ohms (1kHz 1.0% THD)
General Features
Aluminum Die Cast Heat Sink
Power MOS-FET Switching Power Supply
Speaker Level Input
Built-in Variable Low-pass Filter 50-200Hz (12dB/oct) Bch
Built-in Fixed High-pass Filter 80Hz (12dB/oct) Ach
2ohms Load Capability
Size: W 330.0mm x H 59.0mm x D 230.0mm
Same thing as the Audioline amp..only had it in the car for 2hours practically brand new
JB Hi-Fi are selling it for $189
http://www.jbhifionl...ower-amp/435892
Im selling it for $140!!!
Located in Victoria, Melbourne
Contact number 0413597125 If i don't it is probably because im at work. Leave me a SMS and i will get back to you shortly.
https://www.sau.com.au/forums/topic/374140-brand-new-sub-and-amps/
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
