Bench Press(With Leg Workout Attachment) / Standard Curlbar & Weight Plates
Up for sale are a few items i don't need anymore as i am upgrading my gear.
Celsius CX240 Weight Bench With Leg workout attachments.
-Bench workout
-Leg workout
-Adjustable Bench
-Padded grip for floors
-Both seats adjustable for bench/leg workouts.
-Padding for knee and legs when doing leg workouts.
-Safety locks for when adding/removing weights on bar.
Price: $200ono
Comments: Bought this 6 months ago at rebel sport and is pretty much still in brand new condition.
Reason For sale: Building a power rack.
Curl up Bar.
Price: $15ono
Comments: Still in good nick, not bend or damaged. ALSO comes with compression lock collars.
Reason For sale: Just put an order in on an Olympic bar.
HealthSteam Standard Weight Plates with dumbbell bar/collars
Price: $32 for 32KGS.
Comments: Bought these about a year ago, and still in brand new condition. Have no scratches/cracks. These have not been dropped on the floor.
Reason For sale: Upgrading to Olympic weights.
8x 2.5KG Weight Plates
8x 1.5KG Weight Plates
York BarBell Standard Weight Plates Set with dumbbell bar/collars
Price: $50 for 50KGS.
Comments: Have a few scratches and some surface rust from previous owner.
2x 10KG Weight Plates
4x 5KG Weight Plates
4x 2.5KG Weight Plates(one of them is a different brand hence the size difference).
PM me if interested. Preferably pickup only.
Where about in Melbourne are you located?
Are the holes just standard size?
If close by ill take the 'York BarBell Standard Weight Plates Set with dumbbell bar/collars'
Located West of Melbourne, Suburb called Albanvale.
Yeah holes are standard...
Sorry a bit far from me, but goodluck with the sale :thumbsup:
Hi mate,
I'm interested in the Curl Bar and 40kgs of plates (just the 10s and 5s). $50 pickup/meet in the city??
Yeah ill do $50 pickup. ill PM you now.
No worries, thanks :)
hey bud if the curl up bar is still available i'll grab it pm me
Since chef has first dibs, if he doesn't end up buying them ill PM you :)
what is sold, what is still for sale? you can edit the original thread and use the "strike-through" formatting to make it a bit more clear.
cheers.
  • 2 months later...
Good luck! You may wish to try the ausbb forums/nissansilvia's gym section. Or maybe prorawpowerlifting....but not sure if there is a for sale section there :)
  • 1 month later...
BUMP ON BENCHPRESS!! $160ono
cheers.
Yeah i planning on doing that though for some reason, the EDIT button has disappeared?
Ahh never thought of that, cheers... will be doing that now! :)
Edited by silbastian
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
