  • Replies 78
Bit of an update with this. Last night me and my dad had a look at a couple of things to see if we could figure out the most likely cause. Most of the stuff we tried didn't change anything, but two things we tried had interesting results.
Firstly, we measured the voltage drop between the battery and the power line going to the fuse box in the engine bay while cranking. It first drops down to about 9.5v and then goes back up to 10v before finally getting up to 10.5v when the engine catches and I stop turning the key. I mentioned to him about the injectors requiring enough voltage to be able to open, but we were both pretty sure that this must be enough voltage for them to open? Even if 9.5v was too low, surely 10v wouldn't be too low and they should be opening? Or do the injectors require such a high voltage?
The second thing we tried was an attempt to identify whether it was the batteries location in the boot that was causing the trouble. We left my battery where it was in the boot, and used jumper leads to connect the battery in my dad's car to the fuse box power supply. This definitely helped. With the battery connected up there, it no longer cranked for ages without firing. The thing is, it still wasn't perfect. It would still crank for awhile, and then it would sound like it had fired so I would stop turning the key and it would just die. It took a few attempts at cranking to get it to fire, but it would eventually start every single time. With my dad's battery disconnected again, it would go back to cranking for ages without firing.
In summary, it does start better with a battery supplying power to the fuse box, but it still isn't good. If I were to patch a battery into the front again, I would still say it has a hot start problem. So, anyone have any ideas about what we have discovered here?
Well seeing as the issue only started after you relocated the battery to the boot, and patch in another battery at the fuse box seemed to help the issue.. I am still thinking it's a major voltage drop due to the battery location, or poor wiring/bad earth etc.
The fuse box is seeing 10v though. It's a bit low, but it's enough to spin the starter motor, so surely it should be enough for everything else? And how does it relate to heat? Surely if the problem were low amperage or volt drop then it would still give trouble when cold? Why does it only give trouble when hot? Also, the relocation simply made things worse, I did have trouble hot starting before I moved the battery. So could there be something that is heat related and made worse by having a lower voltage?
I'll quadruple check the earth points and wiring. Another thought I had... My fuel pump is directly wired to my battery. Could there be something heat related that causes the fuel pump to not get enough voltage? It does prime before cranking though. I'll check I'm getting fuel to the rail when I get home today.
Edited by Hanaldo
Doesn't heat increase resistance? There could also be a connection that becomes dodgy once things heat up and expand.
When you say the fuel pump is directly wired to the battery, is that 12v from the fusebox? or straight from the battery in the boot?
Bit of a strange update with this, it's sort of just... gone away unsure.gif
Haven't had any trouble for about a week now. Still not starting perfectly, but it's back to how it was before I relocated the battery. I haven't fiddled with anything since I tried patching a battery in at the front, so no idea what's going on. Knowing my car, it's going to come back when I least expect it dry.gif
I was reading about stuff and I came across this.
This non-return valve must not be removed from the fuel pump, removal will result in fuel system pressure loss as soon as the fuel pump is shut down. If the fuel system cannot retain a certain amount of pressure after shutdown, fuel vapourisation may occur in the fuel lines and rail resulting in difficult hot start characteristics.
http://www.bosch.com.au/content/language1/html/4716.htm
Maybe your pump and mine are a bit worn out? I swapped my fuel pump at the same time as my injectors so it is possible that it has been the fuel pump the whole time.
Ok forgot to update, I actually managed to fix this issue before Powercruise last weekend. It turned out to be the earth cable from the block to the chassis, the cable was farked. The workshop that did my engine swap used the oldest, dodgiest piece of wire I have ever seen, it was so corroded and fraying apart I'm surprised my car ran at all. Had the worst crimp onto the eyelet, I didn't even pull it hard and it came out. Then they just wrapped it in tape and put some conduit around it, it looked like a brand new wire. Fkn Perth workshops, there just doesn't seem to be a good one around, why does nobody take pride in their work these days?
Anyway, have replaced the cable with some nice brand new high amperage stuff, haven't had a problem since :D
Man that's good to hear. My earth strap is broken too. I was too lazy to fix it. You should go back to the shop that did the engine and tell them all the trouble you've had with it.
Yeh they seriously couldn't care less hey. My mate had his engine built there, 30k engine build and then they filled the gearbox with water instead of oil, and used silicon to seal the sump. Needless to say it didn't last long and they didn't wanna hear about it when he complained. They also charged someone I know 8k (not including the motor) to install a bog-stock SR20 into an S13, then did the worst job I have ever seen. My mate and myself ripped it out and did it again, did a way better job than they did. They also charged the poor girl 1.5k to install a 'heavy-duty' clutch, but she found it was slipping so we pulled it off and sure enough it was a worn out stock replacement item, looked like it had been ridden hard for a long time. No way it was new, and it certainly wasn't heavy duty.
They also did this:
Edited by Hanaldo
They also did this:
What pricks.
That is a new height of dodginess! and the reason why I do all this stuff myself :yes:
Yeh, I do everything I have the tools and know-how to do myself. Back when I did my engine swap, I knew bugger all about how to do an engine swap or anything like that. Now I've done two :D If I knew what I know now, I would easily have done it all myself.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
