IHI RHC6 bolt on turbo for an RB25DET. It's in excellent condition. No shaft play at all, and spins freely. I have no idea how many kilometers are on it, and I wont pretend to guess. It is in great shape.
If you look it up, you wont find anything. You can find the RHC6 VX81 but not the 24100.
http://www.turbomast...catalog_ihi.pdf
I'm pretty sure its from an APexi kit or some company like that. The RHC6 can be found on a 6.5 liter GM V8 Diesel, but not with the RB25DET bolt on turbine housing, and matching oil and water lines. So I know its fairly good sized. I loved it on my R33. I'm selling the car off so I'm cleaning house of its parts. Boost would come on around 3000, and held 17psi till redline. I ran 20psi off and on, and it would hold that also. I loved driving it.
You wont be disappointed.
I live in Okinawa, shipping will be calculated from here. I ship, and receive parts from Austrailia regularly.
Mike
http://cgi.ebay.com/...KQ3aMESELXQ3aIT
Edited by warp speed
I thought I would attach some pics in hopes of creating some interest. I'll sell if for $600usd plus shipping if anyone is interested. And I take PayPal.I have it on EBay to hit a larger crowd.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
