Fs: Boost Controller, Guages, Intakes Pillar Mount Flywheel R31 Projectors Etc
Got Some Shiz to Get rid of.. BUY IT
No name electronic boost controller has all the usual features plus it is a turbo timer and has 2 aux outputs to control nitrous / water meth etc .. Isnt a flashy name brand thing but it does what its supposed to do
$100
R31 Pillar Mount With Boost And Oil Pressure Guage Complete with all sender units and wiring
$100
Autometer Water Temp Guage No Sender Included But was hooked upto RB30 Stock one And Was Fairly accurate
$30
R32/33 GTR intake kits One is Apexi Other is Unknown Brand With K&N Filters. The Apexi Setup Needs New Filters, The Other K&N Ones Are Less Than 12 Months Old
Apexi Kit $40
K&N Kit $100
R32 GTR Clutch and Flywheel Clutch is pretty Shagged
$100
R31 Projector Head Lights Great Condition i Brought These From Japan About 12Months Ago For Big Dollars Dont Need Them Any More So Get em Cheap
$350
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
