Hey Everyone,
Up for sale I have two full sets of EXCELLENT Wheels in great condition, sizes and offsets. These wheels sit perfect on an R32 Gtst or GTR but would defiantly look great on any other car.
I'm in Adelaide near Blackwood/ Coromandel Valley.
First : White Work Emotion CR Kai's in 17x9 +17, 5 x 114.3 with excellent 90-95% Goodyear RevSpec tyres. $1600 FIRM
post-15679-0-84319100-1315923882_thumb.jpg post-15679-0-72852200-1315923922_thumb.jpg post-15679-0-38316200-1315924018_thumb.jpg post-15679-0-64338000-1315924079_thumb.jpg
Second : Gold Origin DNA-01s in 17x9.5 +15, 5 x 114.3. Tyres are shot but the fronts could still at least be driven on. They are Continental Sport Contact 2's. $1200 FIRM
post-15679-0-11655000-1315924475_thumb.jpg post-15679-0-66212800-1315924509_thumb.jpgpost-15679-0-82228000-1315924651_thumb.jpg post-15679-0-13630900-1315924674_thumb.jpg post-15679-0-23890500-1315925122_thumb.jpg
Would prefer a local sale but can post/courier at buyers expense.
Contact me via PM or for a quicker response Call or SMS me on 0438 86 08 07
Thanks for looking :D
Edited by R32Dreamer
https://www.sau.com.au/forums/topic/377118-work-origin-wheels-for-sale/
You would want to roll your guards at least.
Canada? Not sure at all but I think that would be quite expensive. If u really want I'll look into it, and if u could PM me your delivery address.
Thanks
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
