Scheduled for March 2012 release.
The original was one of the first games to incorporate bitmap images flattened over 3D skeletons. It was the first to use awesome "bullet time" style gameplay. And, at the time, it needed some hardcore hardware to play at maximum settings.
The mix of Noir story and comic cut scenes was a good combination.
The best bit was that you could mod the game however you saw fit.
The third won't be doing anything special like the above lol... but it seems like they're not rushing it either. That being said, MP2 did come out in 2003.
https://www.sau.com.au/forums/topic/377300-max-payne-3/
I liked the matrixed reality mod. For an amateur mod, it was very well executed.
The constipated look was classic lol. They had changed the actor in mp2. He's also the guy they're using for mp3. Apparently there will also be a multiplayer mode, although I don't think it'll be any good;
https://www.sau.com.au/forums/topic/377300-max-payne-3/#findComment-6022218
  • 6 months later...
According to this guy, Multiplayer mode is apparently more fun than previously thought...
Spending Bullet Time With Friends
You're pinned behind a bus in a Sao Paulo transit depot, with a half-dozen mercenaries ready to wipe you from the face of the Earth the second you peek your head past the headlights. You keep still, planning your next move, when out of nowhere some lunatic flings himself from a second-story window and manages to shoot every single one of those armed thugs before he even hits the ground. Immediately upon impact, he pops up as if to say, "I'm good!" and then proceeds to loot each of his victims like a ravenous hobo. Right now that guy might look like the craziest man on the planet, but he's also your teammate. And he just saved your life.......
.......When you engage bullet time, anyone caught in your direct line of sight will have their movements slowed down as well, indicated by their screen suddenly turning a reddish hue. The really interesting thing about all this is that this bullet-time effect can be chained from one target to another. So if your target also happens to have his sights set on a teammate of yours, slow motion will spread to that third player as well. This gives your opponent a chance to either go for the kill he already had his eyes on or simply break from your line of sight to escape the bullet-time effect altogether. It's a clever way of balancing the slow-motion effect in a competitive multiplayer setting, giving successive targets an opportunity to avoid frustration when they're caught in anyone's bullet time force field. And when you manage to turn right around on them and counter their attack with a kill of your own, it's immensely gratifying.
https://www.sau.com.au/forums/topic/377300-max-payne-3/#findComment-6296610
  • 1 month later...
So if you haven't fallen into the Diablo III craze, MAX PAYNE 3 is receiving rave reviews for re-making the third-person shooter genre.
9/10 is not bad for a game that was supposedly never meant to be made...
Gamespot Review
The Good
  • Tight, terrific gunplay intensified by bullet time and hard-hitting violence
  • Great writing, voice acting, and cutscene presentation
  • Detailed environments that get destroyed in spectacular fashion
  • Impactful sound design
  • Fun, chaotic multiplayer.
The Bad
  • Max's shootdodge maneuver is sometimes frustratingly ineffective.
The game is scheduled for release this week - I can't wait.
https://www.sau.com.au/forums/topic/377300-max-payne-3/#findComment-6358393
Good to see gamers on SAU. Im a hardcore gamer spent 5,5 k on my PC. Been playing Aliens vs. Predator since release as a marine i even have my own clan and server lawl. I pre-ordered MP3 and i cant wait to get started on it. But the main gem that im waiting for is Aliens: Colonial Marines that is due out in Feb 2013. Yeap iam a big Colonial Marine junkie and i love kicking xenomorph ass.
https://www.sau.com.au/forums/topic/377300-max-payne-3/#findComment-6379433
Make sure you list your PC specs up the top of the pc and games section in the setup thread.
Never got to play AVP but always wanted to.
Back to Max Payne, so any more thoughts from you gamers? still worth me getting this or give it a miss..... i need something whilst diablo 3 keeps F&*king me over in this patch loop which wont let me play.
https://www.sau.com.au/forums/topic/377300-max-payne-3/#findComment-6380019
Something I never mentioned is that "Max Payne 3 was made in parallel with the console versions and is NOT a port to PC." In fact, the game pushes your PC's limits much like that of battlefield 3. "You're gaming experience is only limited by the capabilities of your machine."
If you're a PC buff, you HAVE to check out this link…
http://www.geforce.com/optimize/guides/max-payne-3-benchmarked-in-a-new-york-minute/#1
The benefits of having a high end PC are well paid off with Max Payne 3.
https://www.sau.com.au/forums/topic/377300-max-payne-3/#findComment-6384583
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
