Recently resprayed in a silver base / blue pearl (sprayed by Madhatters customs).
Paint job is perfect, looks great under sunlight as the pearl reflects *really* well.
Overall condition is very good, very well maintained and looked after.
Handles great from the suspension mods and runs very smooth.
Currently running Castrol Formula-R (going back to mobile 1 next change),
****edit****
just changed to mobile 1 10/30w ($85 for 5L!)
****edit****
oil has always been changed every 4000-5000KM. Marjority of work has been carried out by Hills Motorsport & I have receipts for all parts/labor
Has ~110k on the clock.
Power everything + sunroof
Trust front bar/skirts/rear pods
Bendix Ultimate pads with recently machined rotors,
Recently flushed with Castol Gp600 from RaceBrakes
New (2500k old) excedy organic clutch kit
Whiteline front strut bar
Whiteline sway bars
King springs
Koni yellowsport shocks
Front Camber kit
Adjustable caster arms/kit
Bosch 040 intank fuel pump (supports 400+ HP)
Turbosmart in cabin dual boost controler
Apexi pod filter
Apexi boost gague
Rspec turbo timer
3" custom exhaust from the turbo
Custom oil catch can
Belts/water pump/major service done at 95k.
Idlers replaced, fan hub replaced
Alternator just reconditioned
New GTR Radiator + r33 fan for much better cooling
Leather boots
20% Tints
Remapped ECU on the dyno
Fitted with 2 highend alarms including Quiktrak (total 9 immobilisers).
Rego until Aug.
Looking to sell for 18 - Negotiable.
Please email [email protected]
Pictures can be viewed from
http://www.skylinesaustralia.com/members/brody/
Or in the post directly below
https://www.sau.com.au/forums/topic/37747-silver-blue-pearl-r32/
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
