post-83703-0-27589200-1316437176_thumb.jpg HP Pavilion DV6-6102AX Laptop - NEW IN BOX, UNOPENED.
Pickup available in Sydney Metro area or will post at your expense.
$1200
RRP is $1598 so $400 saving on new one
Processor Type: Quad Core A8
Processor Speed (GHz): 2.50
Installed RAM (GB): 8
Hard Drive Size: 750GB
Screen Size: 15.6"
Operating System: Windows 7 Home Premium
1 Year Manufacturer's warranty. (Buyer's responsibility to arrange directly with HP).
Brand: HP
Model: Pavilion DV6-6102AX
Colour: Black
Features Battery Type: 6-cell Lithium Ion
Bluetooth Enabled: Yes
Digital Media Cards Reader: SD Memory Card, MMC
Hard Drive Speed (rpm): 5400
Graphics Card Brand: ATI
Graphics Card Memory (MB): 1GB
Graphics Card Memory Type: Dedicated
Graphics Card Type: Radeon HD 6750M
Included Accessories: AC adapter, User guide.
Networking: Ethernet 10/100
Optical Drive Format: DVD Burner
Optical Drive Type: Blu-ray ROM
Processor Brand: AMD
Processor Model: 3510MX
RAM Expandable To (GB): 8
RAM Configuration: 2 x 4GB
Ram Type: DDR3
USB Ports: 4
Disk Drives Hard Drive Size: 750GB
Screen Screen Definition: High Definition
Screen Resolution: 1366 x 768
Screen Size: 15.6"
Screen Type: LED
Audio Microphone: External
Speakers: Altec Lansing Speakers
Networking and Internet Wireless Networking: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Connections and Expansion Audio Ports: Headphone Jack, Microphone Jack
Video Ports: 1 x VGA, 1 x HDMI
Software and System Requirements Included Software: Cyberlink DVD Suite, Cyberlink Youcam, Omnifone, Adobe Flash Player, Adobe Shockwave Player, HP Setup, HP Wireless Assistant, HP Support Assistant, User Guide Documentation, HP ProtectSmart (HP 3D DriveGuard), HP Power, Adobe® Reader®, HP Cloud Drive, Windows® Live Essentials.
Dimensions Product Width (cm): 37.8
Product Depth (cm): 24.68
Product Height (cm): 3.11/3.52
Product Weight (kg): 2.54
Warranty Manufacturers (months): 12
Labour: 12
Parts: 12
Processor Processor Brand: AMD
Processor Model: 3530MX
Edited by rhysc1986
https://www.sau.com.au/forums/topic/377702-hp-pavilion-dv6-6102ax-laptop/
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
