My soarer is up for sale due to family reasons (parents won't let me own the car.....)
*120,000 km's
*recently serviced
*runs like a charm, turbo's feel very strong same with engine car feels A1
*interior and exterior are IMMACULATE
*regoed till September
*will provide RWC no worries
$14,000 ONO
if your interested and no bull then contact 0411 132 630
-bryan
https://www.sau.com.au/forums/topic/37871-fs-tt-soarer/
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
