So here's my project. it's pretty un-organized.
Day 1 - Front
Biceps
Barbell Curl - 3 Sets X 10 Reps
Dumbell Curl - 3 Sets X 10 Reps
Alternate Dumbell Curl - 3 Sets X 10 Reps
Chest
Barbell Bench Press - 3 Sets X 10 Reps
Incline Bench Press - 3 Sets X 10 Reps
ShouldersArnold Dumbell Press - 3 Sets X 10 Reps
Barbell Shoulder Press - 3 Sets X 10 Reps
Abs
Hanging Leg Raise - 3 Sets X 15 Reps
Sit Ups - 2 Sets X 25 Reps
Exersize Ball Crunch - 3 Sets X 15 Reps (Weighted)
Day 2 - BackUpper Back
Standing Dumbell Shrug - 3 Sets X 10 Reps
Standing Dumbell Row - 3 Sets X 10 Reps
Middle Back
Bent Over Dumbell Row - 3 Sets X 10 Reps
Incline Bench Pull - 3 Sets X 10 Reps
Lower BackBarbell Deadlift - 3 Sets X 5 Reps
Day 3 - Cardio
Running - 20 Minuites
Cross Trainer - 20 Minuites
Skipping - 10 Minuites
ABS
Hanging Leg Raise - 3 Sets X 25 Reps
Exersize Ball Crunch - 2 Sets X 25 (Light Weight)
Sit Ups - 3 Sets X 25 Reps
Day 4 - LegsFreehand Jump Squat - 2 Sets X 15 Reps
Widestand Barbell Squat - 3 Sets X 10 Reps
ABS
Air Bike - 1 Set X 25 Reps
Day 5 - Variation
Sit ups - 2 Sets X 25 Reps
Day 6 - CardioRunning Or Skipping - 20 Minuites
Day 7 - Rest
https://www.sau.com.au/forums/topic/379248-tims-log/
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
