  • Replies 45
Fairly sure its only a 20 but it does have a rather nice note to it
I give up on the f**kin media link shit just click on it :) Edited by chocco
Sounds similar to the car Steve speaking about. Not sure which i prefer, hard to get the exact from video but having seen the other car in person it was certainly the winner. Best I've heard in 10 years!
Stock 25 head, 3ltr, 6boost manifold with a gtx35. Not sure of the gate/exhaust combo etc.
Sound is as much to do with the manifold, exhaust, gate size, angle/length of screamer as it is RPM anyway.
You could rev to 9000rpm and it could sound shithouse.
That and the S15 with RB25 and the 35R (S15 had non GTX version). Winner.
Panik hands down for me, best sounding RB I have ever heard :)
Looks like a nice video bomb from Nathan Weissel during the interview there. Hard to tell if it's his stag but looks pretty damn close
The blue S15? Funnily enough one of my best mates... Plus all the piping was done by Clint Brown the one who built Panik haha
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
