Love the Smokers........I ride the new TE250 Berg............Nice Build...........what are the wheels off ?
they are marchesini forged aluminium after market wheels...very light
That CR is awesome, that thing would be insane on the street
its quite a wheelie machine theres no doubt about that :)....it has a massive amount of power right off bottom,ive ported the cylinder,reshaped the squish band,clearanced the piston to head,made a decompressor valve for easier starting,v fore reeds,bigger carb,power pipe and made the alloy tank you see that holds 10.4 litres(standard is 7.1l)for a bit extra milage....they are a very very reliable engine but its damn noisey!you can count the power strokes! :)
Edited by ylwgtr2
Thanks mate :)
Here are some pics from the weekend. They are only pics from my phone but should have some high res copies soon.
i had an inkling you were referring to that Matt
i havent spoken to him in ages
wonder what he's replaced it with, i thought he loved his 34, spent all that cash on the genuine ztune body parts
one of the cleanest mod'd R34s in the country, nice buy
how much power is it making ?
Edited by domino_z
It makes 419rwkw.
Matt now has a Honda S2000 which you will see if you are at the S'n'S this weekend :)
just to keep the thread alive....heres another one of mine HRC data card(this model has no key...it has a credit card that you use to start it)hrc jet kit,ethos stainless race chambers and a pair of hrc cylinder heads ...its also ported for a bit of extra mumbo :)
i also have 2 of these......yamaha TDR250...its a twin cylinder 2 stroke road/trail bike.....this one has jim lomas race chambers and some TZ250 gp bike parts such as cylinder head and cylinders.....it goes like the showers of [email protected] very light and tons of fun
Edited by ylwgtr2
i also have a collection of these stupid things....this one is an ATC250 motocross trike....they use a cr250 engine.....this one has a 300cc kit with a custom made expasion chamber that i made.....they dont turn very well and handle like a hat full of ars#oles (live axle,no irs) and scary to take off jumps but its stupidly fast and great for those mud fights :)....i also have one with a cr500 engine in it.....its even worse :D
Edited by ylwgtr2
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
