I just recently install a Profec A, and from the moment i turned it on, the control/soleniod unit made a heep of wierd 'computer' and clicking sounds. After everything was setup up, the unit still makes these noises when the car is turned off but the ignition is on. It seems to me like the soleniods are constantly opening and closing! Is this supposed to happen? All my vacume hoses are setup correctly, and the controller itself is working fine at controlling boost?
Another query, does anyone have the Profec A instruction manual (pdf or other electronic form?) my email is [email protected], id apprecaite it!
Thanks for ur help!
https://www.sau.com.au/forums/topic/38020-profec-a-any-ebc-query/
Weq - I know that alot of solenoids will make a bit of a sound when it initially turns on, but shouldnt keep making it. A mate had an almost new HKS EVC5 and the guy he bought it off didnt have the in line filters installed and had a lot of blow by oil inside.. Im pretty sure he had similar sounds too you and after a quick clean it stopped the sounds.
Re manual, i downloaded a manual from the net when I had my profec a (needed it to set it up properly). Do a search on google or try trust.com - there is a pdf manual around somewhere!
Thanks for ur help!
Noise is normal :) It even says it in the manual, so dont't worry about it
I have emailed you the instructions as well, make sure its set up properly and it should be fine
NOTE - with the learn procedure 'P1', keep doing full boost runs in 3rd and 2nd gears, do as many as possible, as it will make the boost curve more stable, then P2 mode, use 3rd gear
I have found this works the best
Chris
Seriously guys, really apprecaite the info! I was a bit confused with the P1 and P2 learning modes and i didnt spend much time in them (without hte manual, i didnt know!) Boost holds decently atm, but its a bit jumpy up top. I'll think i'll do another setup and see if it will hold boost better.
One last question, regarding the learning mode, what boost level does is it supposed to reach during setup? Like stock wasteage levels? or something preset on the unit?
You get into learn mode by holding power and over take boost down for about 6 seconds or so, it will then come up with -
P1 - learns the stock boost curve, do as many runs as possible, 2nd, 3rd and even 4th if you have a nice big long non-cop patrolled road :) Do as many as you can
Press the power button, it will then go into P2 mode. Press the power button again when you are ready to go, and it will start.
This mode is measures pressure drop between turbo and inlet, one full boost (try to start from around 2500rpm until rev-cut) is alll that is needed, if it is sucessful, it will come up with a digital boost gauge, if it doesn't P2 will still be displayed. Keep doing it until it works :D
Good luck
P.S - dAVE, I think I have emailed the manual to you before as well??
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
