Got a few parts i need gone, rims are more so an E.O.I at the moment but i am willing to part with them.
1. Set of Genuine Volk GT-C's in silver, 17x8 +35 Face 1 and 18x9 +38 Face 2. Fronts clear big brakes, they clear my brembos easily. Fronts in excellent condition, no marks/gutter rash at all, rears have a few small marks on the chrome lip which would polish out. Front tyres are 225/45 zetum sport with around 60% left and rear tyres are stuffed. Include Centre Caps, Rays valve covers and wheel nuts to suit. Chasing $1500 for these which is reasonable considering a pair of 17s alone will sell for over a $1000!!
2. BM50 ABS Brake Master cylinder, in mint condition, will fit any ABS model skyline, great for upgraded brakes - $80
3. R32 GTS-T castor rods fitted with new superpro bushes - $40
4. R32 GTS-T drivers side front clear indicator, believe it is an ebay spec one. mint condition - $50
5. R32 Type M spoiler, black in colour and includes light and wiring - $30?!?
6. R32 GTS-T front swaybar with nolathane D Bushes - $30
Parts located in Adelaide Hills.
Contact on here or 0407 633 573.
Sorry not interested in swaps at all.
Also have a Greddy Type S blow off valve to suit RB25 includes all fitting hardware/mounting plates, and is in perfect condition, $80!!!
Edited by Jms_31
More parts for sale:
R32 Stock suspension, front shocks are standard and rears are KYB Gear Climb. In perfect working order, were used to clear regency - $100
E.O.I - Nismo S Tune Lowered Springs to suit R34 GTT - $450 neg.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
