TEIN suspension for R32 GT-R, great condition, spring seat height adjustable only.
No leaks that I can see, ran great on the car but it's a tad too stiff for daily duties in Sydney (i.e. shithouse roads, I'm too soft).
Turns like a machine.
$700 firm pick up only (no rush to sell these as they are in great condition).
3" cat back exhaust off my GT-R, could possibly fit non GT-R R32s. Has small small 'hotdog' resonator and what looks like an "APC" rear muffler.
Gives your car a great note, selling as I put a quieter system on (I'm getting too old). Has some scratches, it's a 2nd hand exhaust.
$350 pick up only.
Contact: PM is your best bet
I'll get some dodgy pictures later on in the week, busy this weekend.
PM me for my number
$600 for TEINS (I'm getting attached to my current suspension)
$250 for exhaust, it's taking up garage space urrgghh
Also have my R32 GTS-t wreck. No engine/gearbox/front brakes. Diff should be good, power steering was good. Ideal for someone who can drag it onto a trailer/truck. $400 located in St Marys.
Lowball away
I also have another set of struts, front Koni dampers rear standard dampers, Eibach springs all round. I thought the Konis were stuffed but it was the upper control arm knocking.
$200
RB20DET silvertop with R34 turbo, loom, ECU $1,500 I think it has around 130,000 km (can't remember the reading on the cluster).
R32 side mount intercooler $40 nothing wrong with it.
Wreck went to waste (was scrapped).
Everything else still for sale.
TEIN suspension - $600
3" cat-back exhaust - $200
Koni front/standard rear dampers with Eibach springs - $200
Standard GT-R cluster - $40
Standard GTS-t cluster - $30
Standard GT-R steering wheel - $20
Nardi steering wheel - $40 (I paid $100 lol)
RB20DET (silvertop) with R34 turbo, computer/loom - $1,500
R32 GTS-t front brakes (4 pots) calipers/pads/rotors - $200
Standard R32 GTS-t side-mount intercooler - $30
No nibbles :(
Nardi steering wheel - $30 (I paid $100 lol)
R32 GTS-t front brakes (4 pots) calipers/pads/rotors - $200 or swap for R33 N/A front brakes
Standard R32 GTS-t side-mount intercooler - $20
  • 2 months later...
Bump
Standard GT-R cluster - $30
RB20DET (silvertop) computer/loom *no turbo* - $700
  • 7 months later...
Yeah mate, still lying around in the shed.
Note RB20DET is gone.
Looking to swap the TEINs back into my car, so Ohlins suspension might be available soon (very good for street).
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
