Hi Guys,
Purchased this kit through GCG not long ago for my build but the performance shop made custom lines etc not realising i had the kit in the boot for them :domokun:
So i will be selling a brand new complete oil and water line kit for most high mount Garretts on most RB engines.
GCG site -
View Full-Size Image
Oil & Water Kit Nissan RB Series Garrett GT
AU$375.00 (including 10 % tax) XTRFKGT-NISSAN Description:
  • Oil & Water line kit to suit Nissan RB20det/RB25det/RB26dett/RB30et running a high mounted Garrett GT ball bearing turbocharger (GT2554R-T04Z)
  • This kit can be modified to suit most turbochargers (bush bearing and ball bearing), please contact [email protected] for further information and pricing.
As you can see the list price is $375 plus postage which cost me $400 all up... Am willing to let the kit go for $350 which should be fair considering this is a brand new unopened kit including original purchase receipt.
PM me or contact me on 0434 353 292
Cheers
Mat
I'll get a proper picture later, but this is just to prove its new and sealed in the pack...
Kit comes with everything you need -
Oil drain hose and fittings
Oil feed line and fittings'
water lines
All the fittings needed
The fittings cannot be seen in the pack as they are black...
I'll chuck in free regular post for this pack too which will save you even more... :cheers:
Quick update guys, due to the build on my car requiring a cash injection this has now gone up on Ebay too with a starting price of $300 including postage.... Sorry for bumping this but its a bargain and comes with original receipt and is sealed brand new... Would rather it go to an SAU user if possible :rolleyes:
Ebay auction finishes today, get yourself a complete quality oil and waterline kit from GCG today for only $300 posted :woot:
Still for sale guys, $300 posted anywhere in Australia in an express post bag......
  • 1 month later...
  • 4 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
