I have a blitz ecu for sale for an s15 Silvia..... This is an awesome ecu and very rare. I was running 22 psi with this ecu plus 2876r turbo, front mount, 3" exhaust and extractor manifold, fuel pressure reg and it ran beautiful. I want $450 for it as it cost me $500 from Japan. Reason for sale is I thought I lost it..... So I tried to find another tuned ecu which took me 4 months.... And $500 also. So now I have 2! This is an awesome upgrade. No need for tuning. Just plug it in and boost it up. Make killer power on even the standard setup! But it is tuned for front mount... Exhaust and pod filter. Can be used on aus spec. As that's what mine is. Just have to change 3 wires.
https://www.sau.com.au/forums/topic/381484-s15-blitz-access-ecu/
All I did was changed 3 wires on my loom... Plugged it in, then borrowed my mates wide band and wound the malpassi up till it was running where I wanted it and it was awesome. Ran beautiful.....
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
