hey all just got my 1st turboed car and new to this forum sorry if post is in wrong spot lo. I went from owning a vtss gen 3 6spd to ownig an r 33 cant describe how much a better car it its
its got a few mods ill post some pics up soon as i tak em lol its gun metal grey with a drift lip and black 18s the bloke i got it off told me it makes 260kw at the rearsso far its got
microtec computer
greedy boost controller
garret 3076r turbo( i think lol)
6puk brass button clutch
fully adjustable coil overs
2 way diff
044 fuel pump
blitz intercooler
oil catch can
850cc injectors
upgraded coils
strutbraces front and rear
big old pod filter
3inch exhaust
screamer pipe
r34 gtr front and back seats
gtech thingo hooked up lol
bigger slotted rotors
oh and a nismo gear knob lol
https://www.sau.com.au/forums/topic/382765-1st-time-turbo-owner/
Welcome to Skylines Aust!
If you notice your thread missing, it will have been transferred to "Wasteland" > "Newbie" section.
Yes pics will be nice, and try and get the Dyno graph off the former owner too eh?
Had a talk with the Tuner who did the work? If not, you should drop in...
And come to some SAU Events eh?
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
