hey all just got my 1st turboed car and new to this forum sorry if post is in wrong spot lo. I went from owning a vtss gen 3 6spd to ownig an r 33 cant describe how much a better car it its
its got a few mods ill post some pics up soon as i tak em lol its gun metal grey with a drift lip and black 18s the bloke i got it off told me it makes 260kw at the rearsso far its got
microtec computer
greedy boost controller
garret 3076r turbo( i think lol)
6puk brass button clutch
fully adjustable coil overs
2 way diff
044 fuel pump
blitz intercooler
oil catch can
850cc injectors
upgraded coils
strutbraces front and rear
big old pod filter
3inch exhaust
screamer pipe
r34 gtr front and back seats
gtech thingo hooked up lol
bigger slotted rotors
oh and a nismo gear knob lol
https://www.sau.com.au/forums/topic/382765-1st-time-turbo-owner/
Welcome to Skylines Aust!
If you notice your thread missing, it will have been transferred to "Wasteland" > "Newbie" section.
Yes pics will be nice, and try and get the Dyno graph off the former owner too eh?
Had a talk with the Tuner who did the work? If not, you should drop in...
And come to some SAU Events eh?
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
