-South Australia- R33 Series 2 Parts >>> 18 Inch Wheels With Tires,new Carbon Fiber Bonnet And Couple More Parts <<<
FOR SALE:
Wheels brand STARCORP KAOTIC shadow chrome with machined lip 18x8.5 with FALKEN 245/40ZR18 tyres to suit R33 gtst. Fronts are with good tread rears tho need replacement but still driveable, rims overall are in great condition not a single scratch selling cz bought new wheels different style. $750 for quick sale.. picture below is borrowed but its exact model i got..
Resized640x480_100374%2020%20inch%20Starcorp%20Kaotic%20Alloy%20Wheels%20%28Medium%29.JPG
NEW unused carbon fiber vented bonnet r33 gtst series 2.. bought it for $800 now selling for $600
R33%20GTS-T%20VENTED%20CARBON%20FIBRE%20BONNET%20BODY%20KIT%20AERO%20KIT%20AERO%20.JPG
Also got used genuine front left side control arm and also left hand side caster radius rod bracket selling due to lack of knowledge in some of adelaide's work shops.. both for $100 or $50 each.. (pics for this 2 parts on request)
located in SA near Salisbury
Txt me anytime for any question 0415440332 cheers :)
Edited by SAKS
Bonnet and front LHS lower control arm and caster radius rod bracket still for sale..
Come on people this is brand new bonnet never fitted on a car.. The price is i believe good as from ebay or body shop is $700-900..
exact same bonnet i have.. VERY Good price.
also this one has reinforcement on the underside in the same shape as the standard bonnet so when it gets lifted by the police its a lot easier to convince them its ADR certified...
Yea thats the one.. I forgot to take the pic of the underside lol ill have to put it up :) tnx for reminding me
Also got BENDIX ULTIMATE front pads,reason for selling them is they are too noisy for me. Had them less than a week on a car asking $100?
Bonnet $500 if not sold its going on ebay.
Edited by SAKS
Ok this is last price drop.. $450 for quick sale i need it gone as my gbox needs rebuild.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
