Hey fellas I have a set of sparco wheels and need a special lug for them. Here is the link of the only place that will do them that i can find
http://www.galproeng.com.au/specifications.html
Its the third table down and its the "e" one. They want 8 bucks for one and then include shipping on to that. i only need 7 but not really willing to pay that for a piece of metal that size, if any one has any others that will fit or know were to buy give us a message on 0459302735. need them pretty urgently and i dont always have access to the computer.
Cheers Reece
https://www.sau.com.au/forums/topic/382991-help/
Eh, 70 bucks isn't too bad. Imagine paying 300 a set for Rays wheel nuts...
And spares are sooooo handy! I've gone through so many wheel nuts in the time I've owned my car ermm.gif
ha ha yr supposed to do them up with a wheel brace - not just finger tight!!! :action-smiley-069:
https://www.sau.com.au/forums/topic/382991-help/#findComment-6113799
Ohhhhhh, I seeeee. I was just throwing them at the studs like darts and hoping for the best teehee.gif
Edited by Hanaldo
https://www.sau.com.au/forums/topic/382991-help/#findComment-6114009
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
