Ok, This stuff must go, and must go soon!!!
#1 R33 RB25 block and girdle. 86.5mm bore, needs to be taken out to 87, will through in 4 or 5 or 6 ACL forgies (couple of them are stuffed) and 5 stock rods if I can find them, pick up for a case of beer or $50...also has the a/c pump still attached
#2 Good Rb25 crank, standard journals, micro polished, standard short oil pump drive - $50 pick up, or buyer to organise freight from canberra at their own cost
#3 1JZ standard turbo manifolds - $20 + post
#4 JZZ30 standard air box with BFI mod + HKS Panel Filter...filter is ~6 months old - $50 + post
#5 1 blown and 1 good 1JZ turbos - $50 + post
#6 Standard JZZ30 TT Dump and front pipe.....worth nothing can have for a couple of beers
#7 Greddy E-01 boost controller...no solenoid and no map sensor (Im keeping the map sensor for a rainy day)...so unsure if the boost control part of it works (cant access the boost menu without the solenoid plugged in) good if you have an emanage blue and want to tune it....paid shit loads on ebay...got ripped off....yours for 50 bucks + post
#8 JZZ30 intake piping...needs a clean and is badly painted black - $40 + post...polish them and sell on ebay for $500 like everyone else does
Will add more when I think of it
Photos will come tomorrow
and finally located in Southern Canberra
PM me or reply here...don't like the price? Send an offer my way...as this stuff MUST sell ASAP
Cheers
Andrew
https://www.sau.com.au/forums/topic/383058-rb-jz-stuff/
Do you know if the map sensor is required or optional? I plan on replacing my profec n spec 2 with this using the same solenoid but need to know if the e01 needs the map sensor.
How much with the map sensor?
https://www.sau.com.au/forums/topic/383058-rb-jz-stuff/#findComment-6110401
I think I paid $100 for the map sensor from kando dynamic, it is required as it is what the Unit reads manifold pressure from.
For $30 I'll chuck it in too (you can use the map sensor for the emanage anyway)
If the E-01 doesnt work I'll refund the money for it minus the 30 for the MAP sensor
https://www.sau.com.au/forums/topic/383058-rb-jz-stuff/#findComment-6110413
Obviously comes with all the wiring etc? Pm me paypal or bank details mate.
I prefer paypal as i can instant transfer and i need it before the car goes in for engine swap likely this week. Unless you bank nab?
I'll await your pm.
Cheers
Nathan
https://www.sau.com.au/forums/topic/383058-rb-jz-stuff/#findComment-6110454
Before purchase though can you confirm if the map sensor you have plugs straight into this harness www.ebay.com/itm/GREDDY-E-MANAGE-PRESSURE-SENSOR-HARNESS-16401406-/120799146746
https://www.sau.com.au/forums/topic/383058-rb-jz-stuff/#findComment-6110474
Ok, I did have the long loom that goes from the sensor to the E-01..but cant for the life of me find it...I'd still have (might still be in the car)
but here are the photos, loom is a bit messy after being no doubt being on a few cars.
Plug on the map sensor
Screen
Control unit
Map Sensor
https://www.sau.com.au/forums/topic/383058-rb-jz-stuff/#findComment-6110527
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
