Hi all,
Call me fussy but when I start my car (when engine is cold) it cranks over staright away (like in less than a second).
When the engine is at normal temp and I turn it off an then back on it takes like 3 seconds to crank it over..
Any one else have this happen to them? Can it be fixed to start like is was cold?
Thanks in advance.
Rob
https://www.sau.com.au/forums/topic/38340-starting-your-r33-when-warm/
Mine takes about 3 jabs of the throttle to get it kicked over regardless of hot/cold however that could having something to do with my larger fuel pump and also a battery which was "revived" not long ago when it probably should have been replaced :D
Robo your problem is completely normal mait and i wouldn't worry about it.
The reason behind it is because on a cold start there's a lot less lubrication then on a warm start. I've been driving a Ford XF on carbies and on a cold start its takes about 20 seconds to get the bitch to kick.. Yet on a warm start its instant. So dont stress.
  • 1 month later...
Mines a 97 GTS25T and I have a similar thing, although 3 seconds is really a bit of an exaggeration. When I start the car in my garage first thing it fires up instantly, but if I've been driving around for a while yeah it takes about 1 - 1.5 seconds to actually ignite. I notice this even more so when ive been doing several short trips consecutively i.e. to the bank --> to the servo --> to the shops. I have no idea why this happens but I don't think its a problem. I'm probably going to get a bigger battery though!
Hi,
I have same problem with my 97 Gtst. Starts fine when cold, but has a problem after short trips etc. down to shop or servo. usually takes 2 or 3 goes before it starts.
I have mentioned it to my mechanic, and need to look into it. I just replaced the Fuel Filter as the car had started to stall (Auto). Was hoping it would fix both problems, but the warm start issue remains.
hb/
i got a 94gtst and mine does the same thing, it's to do with the idle, your idles at what 650-700, and on cold at 1500 or something like that, because it's so low it takes time for the system to get goin, when mine is warm and doin short trips after the 4-5 stop mine is a real pain in the ass to start, so i general leave it running. If you adjust your idle right as high as it will go, it doesn't do it.
P.s my mate s13 silvia does the same thing, and that does take 3 seconds to start
Guest INASNT
Mine takes about 3 jabs of the throttle to get it kicked over regardless of hot/cold however that could having something to do with my larger fuel pump and also a battery which was "revived" not long ago when it probably should have been replaced :)
U have to actually touch the go pedal to make it start??
I got a 044 bosch pump and if u turn the key to 2 and let it prime for a few seconds then it start easily without having to touch the go pedal hot or cold.
I don't "have" to touch the throttle. I turn the ignition on until the fuel pump cuts out (~5sec) and then as I kick it over I press the throttle twice. I find if I just turn the key it takes an extra few seconds to kick over thats all.
I've only had to do this since I removed the standard r33 GTS-t pump and replaced it with a Bosch 040.
This saturday i'm getting that "idle" issue fixed (cutting the ground wire from the ECU and grounding it to the chassis somewhere). So I guess this means that the fuel pump will be working @ 100% all the time, not sure what impact that will have on anything else.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
