I have got some of these parts listed on this forum but it is getting a bit confusing what is left for sale so here they are.
GTR R34 Left/Right Xenon headlights perfect condition. $1000 plus postage
GTR R34 V Spec Front disc rotors (no Calipers) and complete set of rear rotors(322mm N1) with Brembo calipers all the brake lines. $1600 the lot plus postage.
Genuine HKS purple dual feed fuel rail with fittings to suit 11mm injectors for RB26 perfect cond. $200 plus postage
Siemens 900 cc injectors for RB26 will bolts straight onto standard fuel rail and use the standard connectors (with flow chart of you want it) perfect condition less than 3000 klms old. $400 plus postage.
STD GTR R34 harmonic balancer perfect cond. $130
GTR R34 Rear Tail shaft perfect condition. $400 plus postage
GTR R33 front tail shaft good condition. $150
Call Dave
0412 950192
Xenon headlights for GTR R34 still here, they are in perfect condition with not a scratch , lens are crystal clear
( did have someone buying them but usual story no money)
Cheap at $1000 will incl freight.
text me on 0412 950192
Cheers Dave.
Xmas Bump
I have got a Blitz NUR spec stainless exhaust good condition for a GTR R34.... $450 plus freight.
6 x 800cc seimens injectors, done 1000 klms, perfect condition will supply flow chart..... $400
Edited by SkylineSky
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
