Hello,
Just recently bought a R34 GTR, came with the wheels pictured, not really my style so want to see if anyone out there would be keen to buy them.
Not sure on price as i dont know what they are worth, but know the original owner paid 7k for them.
Wheels come with tyres but they are pretty much gone. they are 19 x 9.5-10.5 wide (not really sure), offset unknow also. very good condition.
Would consider around the 2k mark, or part trades for LMGT4s or TE37 (both in matte black preferably) or stock R34 GTR rims.
Want to move these quickly so feel free to make me an offer if you like them.
Give me a call, txt or pm for any questions and can send more photos if needed, 0435 721 814
Cheers,
Anthony
Bump,
Have some more info on the wheels.
They are dronell Type II with 5-114 PCD
19x10.5 +26 offset
Link below shows info on the wheels.
http://www.globalautoshop.com/wheels/dronell2.htm
Let me know if you want any additional info.
Cheers,
Anthony
Sale fell through as after i got the wheels of the car and cleaned them up i found out the size i listed above is incorrect.
The wheel size is
19 x 10 +18
These are still for sale so let me know if your interested.
Cheers,
Anthony
Forgot to mention not interested in trades anymore, unless locally somone wants to swap with R34 GTR rims....
Will post interstate.. should be around $80-$150 depending on location etc..
Let me know.
Cheers,
Anthony
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
