Hi all,
I am hoping I have put this post in the right category, its my first post :S
I'm sure the topic Intercoolers has come up many a time and people get sick of it, But... I cannot find any info about a specific brand....
Basically I have a Blitz SE Intercooler kit installed and I'm in the process of fabricating up a new set-up. I have a custom front facing plenum im itching to get in there.
I want to know if anyone has any experience of know any information about those weird looking Jasma Delta Fin Intercoolers seen around, more commonly on Ebay.
I guess if feedback is not to good, I will be cutting up my Blitz one converting it to meet my needs. I am just wanting to avoid wrecking a good (expensive) intercooler kit.
Any help guys would be appreciated :D
Cheers
https://www.sau.com.au/forums/topic/384185-intercoolers/
