  • Replies 45
So guys want the parts out of my house asap so im willing to let things go alot cheaper
Nismo Sports Exhaust B0100 AA525 Full 3inch exhaust 3.5 tip incl cat $200
Rear Tail Lights $60 each
Seatbelts $30 each
ABS unit $50
Brake master cylinder and brake booster $50
Rear shocks and springs $50
Overflow bottle $20
Manual Dashboard $60 less then 100,000km on the clock
radiator $50
air condensor $50
passenger seat $50
rear seats $60
Mite negotiate more depending on the item/willingness for the person to buy.
Still have the car its self. If you want certain clips/ screws come down (Clayton South) and take them
0431188213
message if you want any other parts ill tell you if i have it or not with a price
Sold already:
Boot
driver door
Window motors
Clutch Fan
Climate control Unit
Wiper arms
Doors mirrors
few other items
im in the united states. i have an r33. i want to do an r34 conversion. i can get conversion fenders for the front but i need an actual rear clip from an r34 two door to convert the rear. would you be willing to ship parts here to help me out? i need a full rear clip but the rear quarters could be cut off and the rear cut off to ship smaller pieces? all i can find are four door rear clips and most people wont ship to the U.S. i really appreciate any help.
yer i can see what i can do. i dont understand what u mean by the the rear quarter section.
ideally some pictures and stuff would help
  • 3 weeks later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
