Just wanting to see if there's any interest in Adelaide for a R32 four door. 114,000 kms ( have papers and original first owners book ), dark blue, some minor dents and gearbox complains when off acceleration but... Dark tint, Momo race 2000 steering wheel, 260 km/hr Nismo speedo ( blue LED's ), C's short shifter, JVC head unit, quality speakers w/Avalanch amp and DLS 12" sub, Starcorp impul 18 x 8.5, 18 x 9.5 with 235/245, Tein super streets, front strut brace w/brake stopper, rear Cusco brace, centre monkey warehouse brace, rear GTR sway bar, front Whiteline 24mm sway bar, some adj. poly bushes, Reinhard stainless 3" exhaust with twin tail, catco 780 cfm stainless metal cat, split stainless front dump ceramic coated, HKS 2530 w/braid, yellow jackets, HKS EVC-S, greddy front mount, HKS oil therm. cooler and filter relocation, HEL steel braided brake lines, fr. slotted rotors, GTR fuel tank w/044 put intank.. and thats all I can think of at the moment.. majority of parts are new or low Kms. Car has been well looked after and had all the usual glitches fixed like window winder, wrinkled inner window rubbers etc. Looking for $12K but failing that I might end up parting her out... would rather not tho. So like I said, just an expression of interest at the moment to see if there's anyone looking for this type of car. Let me know here or PM
https://www.sau.com.au/forums/topic/384687-eoi-r32-four-door-in-sa/
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
