another item i have to part with is my television, not enough room for it anymore, so for all you people looking to buy the biggest rear projection tv available, i have it and its for sale now,
SONY 150cm rear projection,(HUGE TV) come with serial numbers and was bought a few years back.
its black and im perfect working order but dont have enough room for it anymore.
model number KP-E53SN11. pic can be supplied upon request, make me a reasnable offer and i wont refuse( reasnable doesnt me 50 bucks or 500)
https://www.sau.com.au/forums/topic/38469-for-the-king-of-kings/
D'oh! YEah i really should update.... i still have the nokia 8250 the blue one.... the only pics i can get is those stupid dot matrix ones which people make themselves... damn it... tried to do a search on google for your tv but no luck.... even if there is a website i could go to to see what it looks like and a bit of info?....
no worries when ya get some time e-mail them through, no rush I have always wanted a big ass TV my 68 cm isn't cutting it no more, can you give me a rough ball park figure as i don't want to waste your time if i really can't afford it...
If you like PM me your figure....
well i payed well over 10 grand when i bought it a few years back, and if you look at sony tv's now then youll see that to buy a fairly large tv still costs about 7 grand, so for my tv i think that about 4 grand would be reasnable. or any offer so i know someone might be considering buying it
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
