Rb25 series 2 coilpacks full set with rail $150
rb20 starter motor $50
rb20/rb25 dump pipe
R32 Handbrake setup with lines $50
Stock r32 front camber arms$50
Black good condition momo steering wheel $100
R32 stock turbo $130
R32 bash plate really good quality $180
CEFIRO cat back exhaust have front pipe also $200
R32 stock black spoiler has reverse light $40
Rb coil pack covrr black $25
Greddy fmic for rb20 r32 $300
Stock r32 side mount cooler $15
Ford mesh rims x2 15's 5x114.3 silver & tyres $50
Rb25 shifter $20
Rb25 cross over pipe blocked bov $20
Rb20 bare engine blown $50
R32 blck front guards pair $250 been liped
guard roller blue $200
Harness red momo $50 works 100%
twin pipes/drift pipes brand new never used they have bolt in silences. $150
oz racing wheels 2x 17x9+30 rims good dish, good tyres. $500
red jack its not really low but low over 1000kg capacity .$150
brand new gktech silver cam gears x2 pair.....never opened or used. $240
r32 sunroof spoiler $200 rare as hell
r32 wgan wing brand new from japland painted r32 gtr white $250
orange ramps good as for low cars $50
greddy rb20 r32 fmic $300 all piping included.
r32 bash plate very good quality metal $150
black momo steering wheel $100 no horn.
located hoppers crossing victoria
will post anywhere in aus
sms or ring 0430078630 not on private please.
https://www.sau.com.au/forums/topic/385531-clean-out-skylne-rb20-and-rb25/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
