hey guys,
just wanting to sell my seat and harness as im upgrading to fixed back seat and 5 point harness
BOTH ARE NON GENUINE :thumbsup:
1x Bride Low Max recilable seat
its in good condition, 1 tiny hole on right side and 1 seat base cushion distorted
(im 6 foot with soild build and it fits me snug)
(prefer not to sell the rail with it but its a genuine bride rail suit s chassis)
asking for the seat $450ono
seat and rail $700ono
1x Takata harness, 4 point
ive used it on a couple track days, holds nicely
asking $100 pretty firm on that price
Located Melbourne S.E burbs :happy:
pm me on here
keen on the seat.. I currently have a Bride RO type rail sitting with me just neeed to double check if it will match..
just a FPR backing? how long has it been used for?
PM me if you like as its easier than trying to remember this thread :P
