For sale here is an R32 GTR im asking $35,000 ive owned this car since Dec 2004 an have decided its time to move on.
Lets start with the problems.
Car is very difficult to cold start, possibly just needs a cold start tune im not sure but as soon as water temps are above 50deg C all is good.
There is rust in the driver door, about the size of a 50cent coin. See attached photo. Also when the engine bay was sprayed I don't think it was prepped properly and there seems to be a couple of small rust spots that I have noticed under the pain.
Sump bolt has a small oil leak (this will not stop you from driving the car), not sure if it is just the washer or the bolt is not sealing correctly.
Dash has standard 32 gtr bubble.
Blue compliance plate is no longer completely blue? I will explain further. When the engine bay was washed down to clean all the gunk and crap obviously the solution used was too strong and caused it to strip some of the blue off the plate. See attached photo.
Ok I guess if your still reading these things haven't turned you away and your still interested :)
So what you get for 45grand. Silver 94 built R32 GTR, completely re built RB26 with 4 speed auto and T51R turbo.
Engine:
Crower rods
Aries pistons
ARP Mains
ARP 9/16 head studs
Tomie Cams
Tomie type C Valve Springs
Tomie Adjustable timing gears
Ferro 1mm oversized valves
Trust oil pump
N1 water pump
Trust Oversized pulleys
Trust sump extension
Oil Cooler
Trust radiator
Custom header tank set up
Ross Tuff bond harmonic balancer
Trust timing belt
Trust clear cam cover
Rear of head has oil drain
Intake:
100mm single throttle body
Greddy Plenum
Trust 100mm cooler with 4 inch piping from tank to throttle body
HKS T51R SPL BB turbo with custom rear housing
HKS manifold with split pulse
HKS 60mm waste gate
Garett carbon fibre turbo beanie
HKS funnel
Custom 4inch dump pipe to HKS Super Dragger exhaust
Fuel set up:
HKS Fuel Rail
Bosch 2000cc injectors
Bosch 044 pumps X2
Bosch 040 intank pump
Advan Surge tank
Running gear:
4 speed auto with transbrake
3 speed TCI outlaw shifter with over drive on a switch
TCE 7200 Hi Stall Converter
Rebuilt rear diff
Trany cooler
Exterior:
ARC air diffuser
Silk road head light intake
Pen shift light. not wired in yet
Trust front strut brace
Digital in car A/F gauge
Gizzmo boost controller
Custom catch can
ECU:
Autronic SM4 pnp rb26
Autronic CDI 500R
Brakes:
ABS has been removed
RDA rotors front
RDA rotors rear
Braided Brake lines front and rear
QFM K750 pads front and rear
Brake cylinder stopper
R33 Vspec master and brake booster
HKS Hypermax II coil overs
Rego will be paid at the end of this month so car will come with 12 month Vic rego. No RWC.
Think that pretty much sums it up, car can be viewed anytime yet test drives will only be given to people who are seriously interested in the car and once a deposit has been received.
Car is located in Pt cook Victoria.
I don't want to sound arrogant but ive spent many years browsing these forums so I know some of the crap that is put up in reply to something like this, please if you don't have anything constructive to say do not post it, I am in no hurry to sell this car and I am not interested in the standard R32 you can get for 12grand some where else.
click for pics. http://www.skylinesa...23#entry6119323
Edited by GTR 94
https://www.sau.com.au/forums/topic/386038-r32-gtr-35000/
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
