Hi guys,
Car is S13 with S15 slotted vented rotors and S15 calipers + R32 GT-R master cylinder - car is track oriented.
Used up the last set of pads so got some new ones and dropped rotors off to be machined. They were heavily grooved but the brake shop said no worries as they were still above minimum thickness, he did mention I might need to have an engineering place touch up one or two slots as the driver side inner was a bit wiped.
The below pic is what I ended up with.
As you can see there's still a very notable groove on the outer edge and the slots are baically gone, this is the "good" one in that it still has "some" slots visible.
He didn't charge me but said to go deep enough to get the groove out would have gone below minimum thickness and that at the moment I can just re-slot them and get another few thousand k's out of them. He didn't seem concerned about the groove and said they end up with that sort of thing on street cars all the times.
What are your thoughts Brake Gurus?
Excuse photo, only have iPhone 3Gs on me at the moment.
Cheers
Edited by ActionDan
It's been suggested that it might be better to just use them as they are and not decrease the strength of the rotor any more by slotting it again, any ideas on what performance loss I might see from running non slotted rotors? I am planning on running brake ducts from the front of the car.
What do you mean "go off"? You talking about the pads going off when you're on the track next time? Slots don't really make any difference there. They're not for cooling so much as to allow the friction created gases and dust to escape from the pad-rotor interface, giving a bit better braking overall, but not really leading to less fade. If you're putting in some ducts to cool them off, they'll probably work a lot nicer next time, with or without slots.
By go off without slots I'm more so talking about the pads having nowhere to expel gas and debris, which then builds up and can end up giving a warped feel on the rotor.
I've going to use them as is and have got a deal on some new ones too goo to pass up so will keep those for the next set of pads.
Depends what pads you're running. Very basic street pads do benefit SLIGHTLY from the cooler pad face created by the slots, but any sort of half decent semi track or competition pad it will make very little difference. Look at the really high end rotors (ala Alcon/AP etc.) and their slots are much much smaller than what comes on DBA/RDA etc.
Greg I'm running your pads again after being happy with the bang for buck the first time around.
As it turns out I've rigged up some basic brake ducting into the wheel arch area and am going to use these rotors, I came across a good deal on new slotted anyway and bought those but will keep as spares.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
