What NA is it? I have no info on 20GT's, but RWD 25GT's have M14 front caliper holes, so R32 brakes won't "bolt right on" without some drilling or some helicoil action, as they have M12 bolts.
If it's 4wd, both GTSt or GTR brakes will bolt right on.
Regarding BMC - you should really check what's your current BMC, it'd have either BMxx designation, where xx are digits, or diameter in inches cast on the body.
You'll need no less than 15/16 BMC (also known as BM44) for 4-pot front and 2-pot rear sumitomos,
Better feeling with 1" BMC (aka BM50), R34 GTT has it from factory.
7/8 (what is it, BM38?) is too small, 1 1/16 (BM57) is too big for sumitomos IMO.
It's. 98 r34 25gt so he front cailper whole is 14? Meaning they are the same as the gtt? And if i wanted to fit gtst or gtr I would have to get some sleeves made up that reduces the wholee to 12m? And or the rears would the gtr ones fit? Or same thug goes for it as above?
And I checke the BMc is it the bm50
I've just looked into this and my parts guy reckons the early 34 GT's are 12mm bolts and the later ones are 14mm.
Luckily for me I run adapter brackets so re-drilling/tapping for 14mm is a non-issue.
If I was the OP, I would be going for 32R or 33GTSt brakes over the 32gtst (sell your 32gtst brakes to some silvia guy and buy some 33gtst).
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
