shell - $4500
1993 mspec r32
Clean rego'd shell
sunroof
gtr front guards
geniune N1 gtr front bar
gtr front indicators
BRAND NEW BC coilovers
rear camber arms
front caster arms
hicas lock bar
vanquish roof spoiler
origin s13 boot lip
CF vented bonnet
bolt on rear guards
r34 gtt front brakes with slotted rotors, A1RM pads
nolathene bushes up front
3inch cat back
comes with fmic and piping to suit forward plenum
has engine loom to suit rb25 in r32
CD player, front splits and 6x9 rears
NO rear seats, no drivers seat, no diff, no engine, no gearbox, no wheels.
VSKF - $300018x9-6 and 18x10.5 -5225/40 and 235/40 neutons black with chrome dish
cusco 2way diff - $750
fuel setup - $500
external pump, surge tank, magnaflow fuel filter, speedflow fittings for pump surgetank and filter
defi BF gauges x3 - $700
oil temp, oil pressure, water temp, control unit, light up white with black background
s2 splitfires - $450
ase oil cooler core, filter relocator, block adaptor, speedflow/aeroflow fittings and lines.
$500
eboost 1 with all wiring and solenoid
$350
moroso catch can with k&n filter and speedflow fittings and lines $150
sms me for pics - 0433290801
pics here - http://nissansilvia.com/forums/index.php?app=classifieds&module=core&do=view_item&item_id=1925
https://www.sau.com.au/forums/topic/386979-r32-shell-defi-catch-can-vskf-more/
or individually
r32 N1 gtr front bar with lip - $550
r32 gtr front guards - $400
r32 gtr front indicators - $150
carbon vented bonnet - $500
brand new BC coilovers - $1000
r34 gtt front brakes with slotted rotors and a1rm pads - $600
early r32 brick headlights - $200
vanquish roof spoiler - $150
s13 origin boot lip - $150
1993 r32 shell, sunroof, no running gear, front end or seats, walk in rego - $1000
ase oil cooler core, relocator, lines, fittings - $400
surgetank, 044, lines, fittings, gtr pump - $400
fuel setup - $500
external pump 044, surge tank 1.5L, magnaflow fuel filter, speedflow fittings for pump surgetank and filter
all sensors and even the rad hose adaptor
$350
r32 N1 gtr front bar with lip and vents - $550
BRAND NEW BC BR coilovers - $1000
fuel setup - $500
$350
S2 rb25 splitfires with loom - $400
Gtr front guards - $350pair
Eboost with solenoid and wiring - $300
R34gtt brakes with dba4000 slotted rotors and qfm pads (500kms old the lot) - $600
fuel setup - $350
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
